- Sep 7, 2019
- 674
Ok, I mounted the taper jig up to the lathe and made a taper!
It worked pretty well. At least it functioned like it should. The taper was set at 4 degrees I think and cut into a 3/4" round aluminum bar.
The taper came out a little bit steppy but I think that's from my choice of tool. If I recall they usually recommend a tool with little to no top rake for aluminum but I didn't feel like grinding an aluminum tool.
But overall I'm happy with it. I didn't do any indicting or anything, just checked that it works like it should. On the off chance that someday I need to cut a specific taper I'll have to set it up more carefully. Maybe I'll play around with it and try to hit a specific taper just for practice, couldn't hurt.
After messing around with that I cleaned up the lathe. Oiled all the oiler cups and wiped it all down with WD-40.
