No, it's a scissors box design. The middle cross beam is fixed to the outside legs. The inner box slides up and down. So when the ram extends it pushes on the lower cross beam, which slides the inner box down, pulling the top beam against the middle beam.Upside down? How do you rest the piece to set it for striking?
No, I didn't think to make a thread, but I can give some details. It's a 5 in cylinder, 3000 psi, which generate ~ about 30 tons.I need details!
Do you have a build thread for that?
Depends on what you call the top. The top of the cylinder is fixed to the middle beam. The top and bottom beams are connected, so when it pushes the bottom beam down, the top beam is pulled down against the middle beam.Are you sure it looks like the bottom moves and the top is fixed.
That's a good thought. I hadnt really thought about something being squished under the bottom bar. But I dont think my feet will be at risk. The pivot for the pedal actuator is about 2 ft in front of sliding components, so the closest part is still ~18inches away. Your weight bearing / right foot, would be out side of the frame, so even further than 2 ft away.I thought about feet too but looking at it again just now it appears the base of the frame may already be affording a partial barrier. It’s a bit hard to visualize from the front but judging by where the trip pedal is (at the left front of the base angle) the operator would be standing well back from the guillotine action. A guard might still be an added safety though. Maybe that’s still coming…
just put some expanded screen from the floor to the bottom crossmember in it's up position. Both sides so no one gets hurt.. shouldn't be too hard, and then you can also see into that area.That's a good thought. I hadnt really thought about something being squished under the bottom bar. But I dont think my feet will be at risk. The pivot for the pedal actuator is about 2 ft in front of sliding components, so the closest part is still ~18inches away. Your weight bearing / right foot, would be out side of the frame, so even further than 2 ft away.
