- Sep 5, 2013
- 3,603
Another one of those “how to spend three hours making something that costs three dollars” afternoons today….
I needed a couple of picture hooks to hang some artwork in my bedroom. For those unfamiliar, picture hooks, or “picture rail hooks” were a very common way to hang pictures or paintings in houses with lath and plaster walls. They hang from a “picture rail” that runs around the room a foot or two from the ceiling and saves driving nails into the fragile lath and plaster or, perhaps more importantly, poking holes in your expensive wallpaper. They’re really common around here and were used well into the 1930’s. My house is 1912 so I still have them in some of the rooms.
Anyway, I needed a couple new ones. I like the looks and shape of the old ones but you can’t always find them and where’s the fun in that anyway. I’ve made them before, it’s not a big deal. I decided to use some bronze that is left over from a cymbal resizing I did for a friend a while back. Nice material — rings clear like a bell even in small pieces — and it was about the right thickness.
I traced a pattern from one old hook that I have and then cut two pieces from the cymbal material using the jewellers saw. Then filed and sanded to shape and finish.
To make the large bend I clamped the blank alongside a piece of stainless bar I had lying around. The smaller “hook” part I just freehanded with a pair of flat-jaw vise grips. The first one I did not anneal prior to bending and it was pretty stiff. The second blank I did anneal though, and it bent a lot cleaner. Annealing red metal is easy — heat to red, quench in water, good to go. It’ll work harden again as you hammer or bend it but you just keep annealing it again as many times as you need.
I also didn’t feel like having a highly polished surface on these (plus I didn’t feel like sanding anymore…) so I took them to 320 then gave them a light flame treatment to put a bit of oxide colour on. I finished up with a quick wipe of Boeshield T9 and called them good.
Thanks for looking!
Thanks for looking!
