- Apr 23, 2018
- 7,078
I had a mini project today that turned into a learning experience about metal forming. I was trying to avoid having any learning experience at all, I wanted easy and quick. I got the result I was after, but it went a little sideways on me... literally.
Exhibit A: A plasma table drain that will not drain- not if its rim is higher than the tray's floor- or so I've been told.
This is what I came up with to form a dimple for the drain. It was meant as a single-use tool, so I chucked up a drop of 6061 and was really stingy with the material. No CAD was used, no clearances checked, I barely used calipers. The parts fit and were beveled and gapped until they "seemed right" to me. Even my phone pic was blurry. Whatevs, git 'er done.
And git 'er done I did. This is where learning happened, even though it wasn't what I set out to do. I left a very short tenon on the top die that fit the drain hole nicely, but only the thickness of the sheet because I reckoned good enuff, I was saving a penny worth of material with just an indexing nub. Well, **** fire and save matches, that feature of the die should be the pilot, and just about key to the whole darn thing. I should have made it a half inch longer instead (wasting so much more material), and made sure it met the inner bore of the bottom die before forming begins. Further, I didn't want to have any sensitivity at all while tightening the dies, it was a bit of a reef by hand so I just threw a power tool on it like a jackass. It took a lot of torque but it made a very nice, even, completely formed dimple with an offset hole. Now the lightbulb comes on, where was it a half hour ago?
Pat myself on the back for a lesson learned, from now on I know what to do. Not to big of a deal, the fit-up is perfect thanks to the heavy drain gasket. Dies go in the scrap bin to become something else later. The dimple was perfect and the offset only cosmetic, so that's done. On to the next task.
