- Dec 20, 2021
- 1,066
Over a few days, built a top for the newest HF tool box. This one houses all the grinding wheels, parts, pieces, hubs for the surface grinders and the shars tool and cutter grinder. The tool and cutter grinder will sit on top of this box. The worry was the seams in the box would let grit and junk fall into the box over time. Snagged a chunk of counter top a while ago, but it was just too narrow. Glued and screwed a little strip on the front, routed the edge round. Sawed some grooves so the top lip of the box fit into it, and trimmed the wood front to catch little gussets on the front.
The wood and edges of the counter top were sealed with about 5 coats of poly.
But, before that the new to me table saw needed some work. Ended doing a whole tear down to clean/lubricate sliding parts, etc. First step was removing the top from the saw. Had an "Oh Duuuh" moment about how to do it...
Once In, found the lift mechanism was getting stuck. One of the guide rods had something sticky on it. Very thin layer, couldn't scrape it with a thumbnail, but tacky. Wiped off with brake clean on a paper towel like cleaning a dry erase board! What ever it was, was completely disappeared with brake cleaner.
Then there's the bevel gear box. Why on earth anyone would think a grease lubricated gear box, in a environment full of sawdust, that isn't sealed on the TOP SIDE... Just dumb. Opened that out, cleaned it up, and regreased it. Then SEALED that stupid box form the top side.
The saw has a really nice spindle, with ground surfaces and even the nut is a square or acme thread. The previous owner put a little too much gronk on the blade nut. Flattened the cupped washer out. Had to press that back to shape with the hydraulic press. Next ground the small side, flipped it and ground the large side. Took quite a bit to get it to run at least true.
And, for anyone who made it this far, that little block on top of the tool box... That's a whole different story for later...
