- Dec 20, 2021
- 1,066
So, what is that black box? It's a un-mess up die! To un-mess up something I royally messed up!
Needed a small section of tube to telescope over other another section 2" square tube. Couldn't easily locate anything, so figured I'd make one. How hard can it be, right? Cut some plate, take a section of tube, clamp everything up and shim for clearance plus some extra. I knew it would pull some as the welds cooled. Should have know it shrunk a lot, had to saw the 'form' tube out. Not good.
So, nothing to loose, figured I'd try make a die to drive through the tube to swedge it out. Took a block of mild steel, milled it to size, and milled a groove in the middle. The next step was to TIG some tool steel into the groove to just above the surface. That tool steel 'button' was ground to size, and the edges rounded on the belt sander.
Last step was to grease up the tube and push it through with the press. After a little rework of the geometry of the leading edge of the button, it pushed through just fine. Took about 3T of force in the press after rework.
It might have been faster to remake the tube, but I'm running low on plate right now, so this was a better option. It's a one off part so hard to justify a better way of making it.
Ugly welds not withstanding, it fits the square tube perfectly. This is a sliding drive feature to turn a square drive shaft for a project. So it needs to slide and rotate. The next step will be to chuck the tube in the lathe and knock the corners down so it will clearance fit into the 6916RS bearings. (The ugly parts of the weld will go away in that step). Bearing carriers, and sprocket are mount next.
