I agree the large tpi gear box selection and changing feed directions on the fly would be very nice to have. I certainly like all of the possible tpi on my old SB. The TL would not fit through the hall and the hall way turn going in to the shop area. I even laid out the lathe foot print in cardboard and did trial runs with the cardboard of the installing transport steps ... all before I purchased machine! Also, I was pretty sure I would not be able to fit a lift in the area with the machine so I put it on casters. Maybe I should have just knocked out the wall! However, the bigger the lathe the more it, and accessories, cost.
There are always compromises. So, having a big budget is not the whole story. You have to factor in what you will be using it for. Big machines for big work parts! Small machines for small features! Most of my work parts are not large. Mills: CNC for repetition of parts or complex 3D parts. Manual machine for one off quicker results. My mill is CNC, but there are lots of small cut times I wish I could just turn the crank... not the insentive knob on the pendant. It is not set up well for manual operation. Also if you are doing a hand cut you can both feel the pressure on the crank as well as see the chips etc. Hence, you just slow down or speed up. None of this "intuitive feel" with CNC.
One can never really know what one is getting just from the web sites, manual etc. Even going there to look at the lathe is not complete. I am still learning .... one has to use the machine for a while ....
Dave
Dave
