I flipped the switch and success!!! All this work is starting to pay off haha. I downloaded the driver and software and began the changing of my parameters. First thing I did was auto tune the motor. I also went through and performed most of the parameter changes indicated in your tutorial. From the software I am able to run the spindle forward/Reverse and change the Hz to change spindle speed. When I move the drive lever up and down I can hear the contacts clicking on and off. I can also hear contact clicking when pressing the jog button. My light goes on and off with the E-stop. I feel like I'm nearly there
So I believe my next step is to wire up the logic controls and I need a little bit more detail if you have the time. I can see from the tutorial that wires come from the contacts, 1 from both contacts L1 to P24, and then wires from each contactor T1 go to VFD terminal 1 and 2 respectively. This is where I start to get lost. I can't see from the picture where the wire comes from that connects to VFD terminal 3. Also the wires that connect to VFD terminals ( H, O, and L) where are those originating from? Also it looks like I need to my my current jumper over one spot from its current location.
What style of connectors are you using for the logic terminal? I've not seen anything like this before? Again thank you for the help its greatly appreciated.
