- Jun 12, 2014
- 5,127
Most chucks have either 2 or 3 key chuck pinions, so really not an issue. The chuck rotates easily or bump with the jog. Probably one of the most common requests I get for VFD control systems is for a Joystick Jog, so a very quick way to bump the chuck or turning to a specific spot. A proximity sensor stop used with a VFD will give you pretty much the same exact stopping/chuck position if threading and not disengaging the half nut.I'm new to working with a lathe, but having to rotate the chuck to find the key most every time I stop seems to be an inefficiency that could be resolved.
http://www.hobby-machinist.com/thre...ding-with-a-proximity-stop.45977/#post-391715
The Marathon E467 should work very well and give a little better motor control, but the stock PM1340GT 3 phase motor is very good also. That is a very good price on the one your purchased. The E467 (and stock motor) should easily max out at 90Hz maintaining full Hp. Although Torque drops off above the motor's base frequency, the torque at the spindle would be the same as a 60Hz motor when you take into account the mechanical gearing ratio.
Mark
