Just for giggles, I took the back panel into a car paint store and had them make me up a can of matching aerosol paint. I sprayed some on some foil and let it thicken up a bit. I then used a small brush to fill in all the little paint dings around the machine. I did a pretty shoddy job with the bondo and painting on the column but it looks better than it did.
Not exactly milling with precision, but I used the mill to create the inside cavity in a wood sheath and handle for a sword I forged. The wood is from an ash wheelbarrow handle that I cut down the middle then glued back together after I milled it. Still a lot of work to do to make it look pretty.
Bought some M8x25 replacement knobs for the lockdown levers. The stock front levers tend to catch when you move the x-axis if you don't have them set perfectly.
I also bought a project box, cut some holes into it and mounted it to the back of the DRO display arm. I stuffed all the excess data cables into it to tidy them up a bit. Just need to tidy up a few more and it will be good to go.
View attachment 232804View attachment 232805
Bought some M8x25 replacement knobs fro the lockdown levers. The stock front levers tend to catch when you move the x-axis if you don't have them set perfectly.
Yep they work great. It wasn't really my idea, [fradish] mentioned he had made some knobs for his. I don't have a lathe so just bought mine. For less than $8 per pair and free prime shipping they were hard to beat.
Since this is "the go to thread" on the 727, I've got a note, w/ pic, and a question.
First the note, drained the gear oil today, again. Got curious, so vacuum filtered it to see the particulates. Oh boy... (see pic for what I mean).
Now the question ...I changed the oil because I noticed a lot of play up and down on the quill when I use the fine adjustment. Has something gone bad, hence the metal debree? What/where should I look first to resolve the play issue?
Side note, I'm going to completely flush the gear box this weekend.
