I installed the Y-Axis on the left side of the machine to prevent interference with the Y Locks and mounted the X Axis reader to the front.
Make sure you measure and mark the table and saddle travel before you begin. In the pictures below you will notice green marks (lines) where I did that. This allowed me to make sure I aligned the scales and readers properly to allow for full travel (allowing for extra travel on each end for safety).
Here you can see the X-Axis scale is mounted to the table using the dove tale track that was already machined into the table. The Scale Reader is mounted to the saddle with an L bracket.
I marked the center of the saddle along the X and drilled / tapped two holes (10-32). They are the two lower horizontal holes.
Y-Axis mounting was more work. On the left side of the machine I made a standoff that I mounted to the casting with two countersunk cap screws. I drilled tapped holes into this standoff for mounting another bracket to extend out over the base casting.
-Denzil
