- Nov 9, 2015
- 427
Two things that I am wondering about. One is what size boring bars should I drill the holes in the head for? I don't have any metric drills and my imperial drills are in 1/64 increments. I am leaning towards 1/2" boring bars. Other choices under consideration are 3/8, 10 mm & 12 mm.
You might consider making your boring bar holes as large as is feasible, which gives you the flexibility to sleeve for smaller diameter bars. The boring head I use has 1/2" holes, and so far I have made sleeves for 1/4", 6mm, 7mm, 8mm, and 10mm boring (and threading) bars.
