- Dec 30, 2017
- 117
The SAE gear oils you will likely find will be for automotive transmissions and especially hypoid geared differentials. They have high pressure additives (sulfur) which will eat yellow metals (bronze, brass, copper, etc.) Do not use those oils in your lathe.
You can also use ISO68 gear oil, like Mobil DTE26.
Okay, I thought the ISO number and the SAE number were just different scales of viscosity? Because if that is the case it would seem that these two quotes contradict each other...
And where can I look to get a five gallon bucket for less than $30? Tractor places?
