- Jun 22, 2023
- 624
Mr Mike, you asked me not to comment on your posts before but since you quoted me, if you look the marks do not appear to be under the dovetail or on the dovetail itself. I agree, if not proud of surface, hence the statement "if they are proud of the way surface", do not stone them. please do a little reading on machinist stones, the stoning with a perfectly flat stone will only take off the proud parts and leave the way intact. in fact that is the prefered method of dealing with knicks on machined surfaces.what stone are you using that will be able to get underneath the dovetail area, to clean up the full width of that way..?
Is there a stone that has the proper angle built in that can deburr both faces at the same time..?
Also I thought I read that those indentations on the ways helped hold way oil, I could be wrong.... I certainly wouldn't stone them unless they were proud of the surface... wouldn't the ack of trying to stone those marks out induce uneven wear to the ways..?
last but not least, I cant tell if 55fairlane is just joking, if not you can borrow my positive energy shield, it will protect you
yes the indentions (if they are only indentions and not proud) would help with oil retention although that pattern is not optimal for that.
I think that 55fairlane is joking (I am) while feeling sick so it is the best he can do right now.
