Some progress, at least as far as the hardware goes:
This is an array of eight AM241 sources, epoxied around the aperture behind which will be the 100mm^2 detector. Yes they're ugly and canted this way and that, but since I don't have any lenses to focus the x-rays anyway they'll do
. Having 8 of these things shooting 60Kev xrays out made me pretty uncomfortable, so most of the time the source plate is inside a .125 inch thick lead shield.
I milled 8 recesses in a bolt hole pattern to help place the sources. I had the thought that milling the holes deep enough, then using the tabs to tilt them toward the sample volume, would maximize the x-ray flux -- but the end result wasn't quite as nice as I'd hoped. The x-ray emission pattern is pretty broad so I don't think it is a big deal.
I debated over installing all 8, since I'm not really sure what the count rate will be -- but if it's too high I can make some lead shields to block some of the sources. This is a PROTOTYPE so by the time it is producing decent results (if ever) it could well resemble a porcupine. Or (most likely) a real Rube Goldberg assemblage.
For a sense of scale, the aluminum plate is 2.5 inches wide and 4 inches tall. It's .25" thick so the 60Kev x-rays emitted from the backs of the sources should be pretty severely attenuated -- my spreadsheet indicates that a little less than 1% of the x-rays would make it out. If that turns out to be too much, I left enough room on the other side to place another shield -- lead, aluminum, whatever. Another sheet of .25" thick aluminum would drop the intensity to 1% of 1%, i.e., .01%. In the mud.
Some might worry a bit about x-rays from the screws that are used to hold the box together and mount the latch. However, the aperture acts like a collimator to restrict the detector's field of view -- so all it should "see" is aluminum. Since the x-rays from aluminum are expected to only be in the 1Kev range, that's not a problem -- that energy range is at the very low end of the detector's sensitivity curve.
