Got a circuit to simulate using two LT6230-10's. A 1nA exponential pulse generates a 131mV pulse at the output of the second stage. Not a very fancy circuit, but it seems to work over a 3 decades of current. At 33pA, it outputs about 4.4mV, at 33nA it is just below saturation with a peak voltage of 4.2V. Yes it will have to be reduced in amplitude at the output. At the very low levels there's all kinds of weird stuff happening, bias current and input offset that is getting amplified up. I'm sure there are things that can be done. But having enough GBW is making this a lot easier.
It's not clear to me, what currents should be used. I used a dark current of 1nA, diode resistance of 40Meg, and diode capacitance of 150pF. I capacitively coupled the diode to the TIA using 100nF. Powered with 9V at the moment. At low impulse currents the output gets lumpy in the tail of the exponential. High currents look good. Pulse doesn't change characteristics, it just gets taller as it should. Whether this circuit actually works in real life remains to be seen.
10pA impulse. It settles out after a while. It might in fact be a simulation artifact. I have a minimum 100ps time step.
Impulse at 32nA.
On a completely different note, I was surprised to see today that @homebrewed Mark's circuit board arrived! Two days from the West Coast, that's pretty quick. Thank you so much!
Now I have to go shopping for parts... I'd like to settle on this front end though. Seems it is a critical element.
Impulse at 32nA.
