- Jul 28, 2017
- 2,624
The comparator is an open collector job so C16 is part of a pulse stretcher. That's my take on it, anyway.My Pocket Geiger is to arrive on Saturday. Is C16 (4700pF) really hanging off the end of U3B (LM393) voltage comparator?
Edit: What is the part U4? It claims it is an LT1651, but that doesn't seem to be an active part, anywhere. Ah, an LT1615 seems to have the same outline and function. Jeesh. I think according to the numbers, the switcher would supply about 13.5V to the NJM regulator. Not positive if that is a doubler, or tripler. Tripling the voltage would make it about 39V, give or take. That's a nice high bias voltage. What's interesting, or rather sad, is there's no information, at least on the Sparkfun site on how this works, or even how it is wired. What is the function of the JP2 block? What is the baseline configuration?
It would seem the top comparator threshold is 3.089V, this is "pulse". The bottom comparator threshold is 2.686V, this is noise. I understand the comparator outputs won't be used in our application, but it would seem they are using these "signals" to validate the pulse.
I believe that 4-diode network is a doubler. IIRC, I measured the bias voltage to be something over 26V, also not too bad -- but the switcher couples a lot of noise into the amplifier chain. Not too surprising, considering the high gain.
I don't know if JP2 is there for testing the board once it's been assembled, or if it is an option that isn't used. The footprint is on the board but it's not populated with anything. It looks like the board could be operated with outboard power supplies via JP2 so the detector, amplifiers and comparators could be tested before mounting all of the on-board power supply stuff. I haven't checked prices on those components so I don't know if it would make sense to do that or not. Test time can be expensive so doing it twice may not pencil out.
I think the "LT1651" is a typo. I didn't find a DS for it, either; and the LT1615 looks right.
