- May 27, 2016
- 3,477
Not to worry. That one comes about if you have the .lib file in the LTSpice editor, and you right click on the SUBCKT name of the part, and it pops up a box asking if you want to "autogenerate" a default symbol with the right number of pins to use in the circuit. Once in, yo can edit it, move the pins about, etc. and save.@graham-xrf I don't seem to have an Autogenerated subdirectory under sym. I can create this, but is it necessary?
Under home, it is .wine/drive_c/users/bruce/My Documents/LTSpiceXVII/lib/sym as I said, there's no Autogenerated . First folder is ADC. I have display hidden directories ON.
I already went through all that, and I dumped the yellow box symbol, and drew lines and stuff to make an op-amp.
You very likely only need to create the Autogenerated folder in the right place, and put the symbol I made into it.
There are several YT videos about doing this stuff. Look in the text file here. It also has hints.
I know you went looking under .win/drive_c path, but notice that it uses a symlink to point you back to your home folder.
Open your home folder, then look in Documents, and see LTSpiceXVII.
My path was /home/graham/Documents/LTspiceXVII/lib/sym/AutoGenerated
My Linux happens to be Linux Mint, which is Ubuntu-based, but I think all Linux distros have a Documents folder.
