- Dec 18, 2019
- 7,760
The long and short of it was I cried a lot and bought the Prusa i3 MK3S+. You can discover the latest price at: i3 MK3S+ The reasoning behind the final buy was I did not want to make the printer itself become a hobby. Read about a lot of other people, and they required modifications to print ok, and most if not all the modifications are already in the Prusa. It's not the most advanced printer, but it is solid enough, and gets prints done. And right now, that's all I want from it.@WobblyHand
Do tell about the printer. We can maybe benefit from some of your agonizing.
I mean, what model, and how hurtful to the wallet?
Even though I'm retired, I didn't want yet another time consuming hobby, I just wanted to be able to make some things that would be useful to me, like custom electronics housings. I made a housing for my doppler chronograph, and my ELS controller. Both units have touch screen displays. I basically printed directly from my FreeCAD designs. To have made those housings in metal would have been far beyond my machining capabilities. The downside of 3d printing is that it is not particularly speedy. One is building up an object one thin thread of material at a time.
Picture of my ELS box. Not shown are the GX aviation connectors, the cables, or the magnets. You can see the four pockets on the bottom side. I pressed in some 12mm magnets so the box stays upright and stuck to the headstock. I've made two of these boxes now. The second was an easy print - I didn't have to adjust anything - it just printed out, and everything fit. You can export an stl file directly in FreeCAD. The box was printed, then the cover. I used thermal M3 inserts to hold the cover on. Use a soldering iron set to 215C or so and slowly press the insert into the proper size hole. Works great.
I bought the 3d printer kit, hoping to save some money. I did, but it took me a while to build it. By the time I had finished, I thought the assembled unit was a bargain. Nothing was hard, but it took a while. There's a few places that you can go wrong, and you don't know it until sometime later in the process. Then you have to undo some stuff. Personally, there were some steps that are meant for very young nimble fingers, that took me a while to do, or they were mechanically awkward to perform. However, once it was assembled, it wasn't super hard to get going. There's some gotchas in 3d printing, that I stumbled over. But that's pretty much the same as in machining.
You can buy something a lot cheaper, but you will have to put in a bit of time. Classic tradeoff... Prusa's thing is it just works. My experience is they are right.
