What does the frequency response of the amplifier chain look like? If there's a lot of attenuation at these low frequencies then not much gets through. Of course if one has 60 dB + DC gain then a lot of power line frequencies will get through.
Honestly, I don't know how it can even respond to 60Hz. It looks like if given a "sudden pulse", it will wander up slowly to (some) level
The gain of the circuit is not at all 60dB. more like a couple of hundred dB, but we have to take care about what is gain in a TIA. It's dV/dI, which is expressed as dBΩ. By calculating backwards, starting with a nice full height 2V pulse into the ADC using 2.048 for it's maximum count 65536, and dividing by the gain, I tried for for how much of a current pulse started out.
Even though I drastically reduced the gain of the TIA by setting Rf = 1MΩ instead of 66MΩ, and adjusting the next stage to have gain x220, the total is still about 2.2 billion, (including the x10 gain on the signal conditioning board). The pulse that started out would be about 0.9pA. One of my previous attempts at counting electrons into 230pF in 13uS estimated 45pA. Certainly less than the 2fA to 4fA bias current, but I can't really reconcile that with the rest of the datasheet, hence the desire to try LTSpice.
Simulate the LMC662 ?
I wanted to do a (careful) restricted simulation of the LMC662, and I have downloaded a PSpice model from TI.com. It looks as if it will be usable for LTSpice, possibly after some compatibility edits, and a read through. The text warns that "asymmetric gain is not modeled" which may have something to do with there being two opamps in the package A and B. It also warns that noise is not modeled, though this might be added from using the datasheet and stealing from the LTSpice model.
I know the Pocket Geiger was always a threshold driven Geiger pulse maker, and I agree wholeheartedly that purchasing one just to get hold of the PIN photodiode is well worth it. I never did think the electronics would do, and the tracking itself was awkward for the pin-outs I wanted to use, which is why I did not try and use it.
Then Mark powered up, and started measuring stuff. I am envious at the progress, but I am concerned that the little circuit may be giving him confusing symptoms. Real known pulses is something one cannot argue with, and I can only admit my lack of understanding. Yes, if I have a chance, I may try and verify with LTSpice, but not now. I have enough else to catch up on, so I am seriously considering working up something on that evaluation board of post #1180.
KiCAD
I have been getting this added to. I have made a symbol for the Raspberry Pi header interface. I planned to add in the connections for ADC and all that to the Teensy. I got the library yesterday, but it's not yet integrated into KiCad user library path.
LTSpice verifications
My two basic circuits have been simulated, including .OP state to see if there is offset buildup, and noise simulations from 1Hz to 1MHz. The "simpler" version is almost college electronics simplistic, using LTC6268 so I can have guard rings. I have simulated with current pulse of about 45pA, and another of 2.85nA. My calculations of how many electrons result from a 59.54KeV direct pulse from Am241 are not consistent. I won't embarrass myself by putting them here (yet).
I also added an (optional) mains noise notch filter. I trawled several types, and I discovered that some intially disappointing notches would magically reach to spectacular dB depth just by changing the frequency sweep to 20Hz thru 80Hz, and setting it to "linear" with 3200 values. One of the state-variable types gave great results, but it may not be best if one wants to be sure of not saturating the op-amps.
The mechanical stuff
Not forgotten! You will soon be wanting to go for some 3D-printing. I am trying to figure how to drill the tilted holes. Mount the source carrier at an angle on a rotary table vise I think. Maybe just make them face straight ahead? Anyway, playing with FreeCAD must also be done.
Oops - OK, it's that time of year. I just got the PM to renew the donation.
