- Sep 3, 2023
- 352
Please do not take the following the wrong way but, I am a bit sinsitive to the terminologies used, they really do have meaning in the real world.
I get your point; but, you continue to use 200CF which means very little, If you want 200SCF of gas the actual size of the cylinder will vary based upon the cylinder pressure and gas.
Please note, in the industrial gas world which includes welding cylinders that:
ACF sometimes refered to as water volume stands for "Actual Cubic Foot" which is the physical internal volume of the vessel/tube/cylinder/bottle.
SCF is the uncompressed volume of a compressible fluid such as Oxygen and stands for "Standard Cubic Foot"; therefore, 200 SCF will compress into a small ACF but it is still 200 SCF.
A large cylinder is a 3AA-2400 which is 9" OD x 55" tall and it has a water volume of 1.7ACF +/-, with Oxygen that cylinder at 2400 PSI will hold 174.92 SCF per ACF or a total of 297.36 SCF. As a comparison the same cylinder same pressure full of Nitrogen is 159.48 SCF per ACF or 271.12 SCF total cylinder volume. Now, if you can find a cylinder of this ACF in a 3500 PSI full of Nitrogen is 220.263 SCF per foot or 374.45 SCF total cylinder volume.
With all of that said, the 3AA-2400 cylinder is a fairly large welding bottle and expensive for what a hobbiest needs, the 3AA-2265 is the bottle(s) that I have and I think you are talking about, this bottles full pressure is 2265 PSI at 1.3 ACF +/-, with Oxygen that cylinder will hold 163.99. SCF per ACF or a total volume of 213.2 SCF and is common and inexpensive relativly speaking.
Just as a side note for those who actually read all of this, Compressors use CFM "Cubic Feet Per Minute" to tell us how much SCF of volume they move, not a true volume of storage, the compressor tanks or recievers are typically rated in gallons which is uncompressed volume (water volume) which means a 15 gallon reciever is actually 2 ACF and at 120 PSI holds 7.928 SCF per ACF or 15.86 ACF total; so, A little more than 1 SCF per gallon....
I’ve been around welding / cutting gases for over 40 years. Several different welding stores, buyouts, mergers, and so forth in my area. Now the nearest true welding store where I can get gases filled is 4 towns over about 40 miles away.
With that said, each time someone new bought out existing business, it seemed the names of the tanks I once knew, changed. Contents usually the same, but maybe a bit different volume of gas. Sometimes, based on how high of pressure they actually fill the tanks to.
I remember most of the time when I was a kid working with my dad, oxygen tanks were always at least filled to 2500 psi. Nowadays, when I get a new tank, it is usually only 2200 psi. Why? Safety reasons? Or just companies way to raise profit margins? Fill the bottles a bit less, and keep price the same?
Oxygen tanks have several different names for the sizes they are. I think a lot of it has to do with how it was known in that area years ago, and terminology will be different in different parts of the world.
Anyone want a pop? Or a coke?
Now, as far as welding, brazing, soldering, terminology, I think of brazing and soldering as like holding two parts together with hot glue. The parts can be dissimilar metals. You melt the welding rod to join the parts. The rod does not mix with the base metals.
Soldering is usually with a lower temperature filler. Brazing with higher temp filler metal.
Welding is joining two base metals by melting, with or without a similar filler wire.
I was taught in school gas welding with Oxy-acetylene. I was told that you cannot gas weld with oxy-propane because you cannot achieve a neutral flame with it. Has to do with more chemistry that’s over my pay grade. If you actually want to gas weld steel, you will need oxy-acetylene set up.
I’m not sure about gas welding alum, or other non ferrous metals.
But since soldering and brazing is only melting one metal, the filler metal, you can use oxy-propane, or propane only if that is capable of getting your base metal hot enough to melt the filler material you choose to use.
