Do you guys know that you can stack blades to get a wider kerf? This is especially useful when using the thinner jeweler's saws; just stagger the teeth as best you can. This is why the Sierra American design is so good. It allows you to accurately stack two blades and hold them concentric to the body of the arbor. If you do stack blades, slow down your speed and definitely manually feed it so you can feel the cut.
Didn't know that, but makes lots of sense! For that matter, didn't know about burying the saw. Always been a bit scared of doing that. Have stalled the mill with the saw going in too fast, so have backed off on the feed and taken lighter cuts. PM25 doesn't have the grunt of a bigger mill, so have to accommodate that. @wachuko 's mill won't be fazed at all.
Grizzly Industrial, Inc. is a national retail and internet company providing a wide variety of high-quality woodworking and metalworking machinery, power tools, hand tools and accessories. By selling directly to end users we provide the best quality products at the best price to professionals...
www.grizzly.com
Harvey tool has high end carbide saws upwards of $600
www.grizzly.com
I've stacked two blades and taken full depth cuts on a Sherline mill. The trick, if there is one, is to feed manually so you can feel a slight resistance to the feed. You will feel and hear the saw cut. I use both hands to maintain a constant feed rate and use my third hand to lubricate the cut. You do not need to baby a slitting saw if the holder is accurate.
You should also have a splatter shield or wear a shirt you don't mind having a permanent stripe on because I guarantee you that you will be wearing a lot of cutting fluid when you're done.
It doesn't have the low RPM, either. Get much over two inch diameter and the blade speed is too high. A four inch blade would be great, but the slowest RPM would smoke the blade shortly.
