- Nov 14, 2016
- 3,350
Presumably the build quality is better on the Emco, but it is still basically a slightly smaller, less featured Grizzly G4000. Emco made some very good quality lathes, but I get the feeling the Compact 8 was the result of Emco trying to cut costs, so maybe not their best effort. I see Compact 5s generally sell for more money than the larger Compact 8.
The Grizzly G4000 and other branded 9x20s came about when Emco moved production from Austria to Taiwan.
Not sure when Emco stopped making the Compact 8, but believe it was done by 1990, so minimum 35 years old. Maybe not an issue if well cared for but the surface rust and missing change gears does not say well cared for.
Parts for 9x20 are readily available, Emco? In general Emco parts are not cheap, and I'm not sure how much parts commonality there is between Compact 8 and a 9x20. The Compact 8 is an 8.2x18" lathe while the 9x20 is an 8.75x20" lathe, so while there is probably some ability to make 9x20 parts work, I am also sure there are parts that will not fit between the two.
Maybe if I ran both side by side I might have a different opinion, but personally I'd probably choose a 9x20 lathe over the Compact 8 all other things (price, tooling, condition) being equal.
