- Aug 6, 2015
- 4,307
I did not get why the need for a 6-jaws... What got me interested was the 4-jaw combination chucks. These chucks have the features of the self centering type, as well as independent type. This enables the jaws to achieve a self centering clamping and, be adjusted separately.I'll throw this out there. For a 12" lathe, I find a 6" 3 Jaw chuck, an 8" 4 Jaw chuck, and a 10" faceplate are the most appropriately sized. A 6 jaw chuck is expensive and unnecessary unless you plan on doing work on delicate tubes. My only other purchase I'd like to add would be a 5C collet closer, but that can be down the road many years.
I got my 8" 4 jaw from an import supplier. Works well but I have definitely noticed the issues with jaw lift and perpendicularity of the chuck face and jaw step faces to the rotation axis. I can work around it but it takes more effort to set up that a higher quality chuck.
That all being said, I can dial stuff into concentricity and perpendicularity within tenths if I give it some patience.
Would that be the only chuck needed? I guess not, for certain parts where only a 3-jaw would work... But I venture to guess, that in my case, something like that would be the only one I would leave on most of the time. But way too expensive for me to consider one...
Anyway, back to reality...
Got out some of the aluminum stock... started to cut with a saw, since I do not have a bandsaw... well, father-in-law mentioned he had purchased a handheld one many, many moons ago, from Harbor Freight... Sure enough... and it was not even sticky...
All I have to say is that I am never going to use a hacksaw again, ever... Using this was sweeeeeet.... Now I really want a 4x6 bandsaw!!
So I place the stock in the chuck, face both ends... and started to drill... Please excuse me, but it will take me awhile to get used to seeing the drill bit fixed while drilling the part . I was just smiling watching that...
I need to drill a 12.1 mm wide hole, 16.7 mm deep
So I still have not installed the QTCP... using the one that came with the lathe. I got to practice using the tail end, self-centering drill bit, drill bit...
I got to the desired depth (accounting for the roundness of the drill bit) but could only get it to 11.8 mm with the drill bits that I have... I do not have one that will get me to the needed diameter, next up would go over the diameter needed... and I am not ready to practice with a boring tool... if I can't find a matching drill bit I will have to bite the bullet and give boring a try...
Wait, I have a 12mm 2-flute end mill... that could work, right?
Side comments...
The chuck-key needs to be taller and with longer handles... a bit of a PITA to have to move the chuck so I can clear the chuck-key to tighten the part...
I need an LED lamp with a magnifying glass...
I need a multiple outlet strip installed on the bench...
