Mill saved my life last night!!!!!!
dabear3428
H-M Lifetime Diamond Member
Jun 22, 2023
751
well not my life so much as my night lol.
was replacing the hydroboost hose on my duramax, late at night on a thursday needing to go to work today, and get everything pulled apart only to find that one of the nuts for the compression fittings that is in the worst possible location was an 18mm, you guessed it, not one of my 10 sets of wrenches has an 18mm and it was too tight to get an adjustable in there. After a lot of head scratching, searching, then cussing the light bulb goes off, i have lots of 17mm open end wrenches that would fit in the location so 5 min setting up the swivel base on my vice and a little work with an end mill and there was a nice 18mm open end wrench allowing me to get the job completed.
What brand wrenches do you have? Years ago I tried to thin down a Crescent wrench to get into a tight spot. A HHS mill barely touched the surface. It dulled before I had cut 1/4”. Rather than ruin any more end mills I went to the local farm store and bought the correct size wrench.
I considered buying a carbide end mill, but the wrench was cheaper the the end mill I needed
had some cheap carbide end mills and the wrench was an old craftsmen that i had inherited with lots of rust (removed with evaporust). i had thought that the chrome would have been an issue but it turned out not so much.
