- Nov 16, 2012
- 5,596
For precision parts of O1 tool steel, it's best to fully normalize the metal before working on it. Also, make the part slightly oversized so after final heat treating, you can grind the part to final size. That is the recommended procedure for precision parts made of tool steel. To normalize the metal, bring it up to 1600 F and let it gradually cool in an open oven until room temperature. Once you do this, the metal will be very soft and cut like butter using normal HSS or carbide.
Yes, tool steels are a little expensive -especially if you purchase first-rate material with certifications. I usually settle for the odds&ends pieces that most suppliers sell at a slightly lower price.
Ray
Ray
Yes...both parts I need to make are small...just a hammer and trigger. The Metal Supermarket here has a bits and pieces section as well. I was in a bit of a hurry by the time I got there, so I just grabbed a bar they had on the shelf...walked up to pay for it....choked a bit....and hurried along to my next stop.
One thing I should ask before sacrificing another perfectly good end mill to the gods of inexperience. What end mill material should I be using on this stuff ? Should I be looking for a pure carbide one, or will the HSS or cobalt ones I already have do the job ?
