I am a retired toolmaker. First of all,you need to get a good book on tool steels,and not try to rely on the scattered and contradictory information you will get on a forum,from a bunch of guys whose expertise you do not know.
A good all around tool steel for the parts you mentioned is 01. Take a flat nosed punch and stuff any holes in your parts with fine steel wool to stop the risk of the parts cracking where there are holes. The steel wool makes the parts act like they have no holes. If you do not bother to do this,be prepared to spend all day baking a part,only to possibly have it crack when quenched. No one here mentioned the dangers of quenching parts with holes.
Be SURE to quench in the correct medium. We used automatic transmission fluid in the tool making shop. Yes,with larger parts like plane iron blades,it will flame up a bit,but goes out soon. You can use vegetable oil,or peanut oil as suggested. Do not try using water or brine with 01,which is an oil hardening steel.
Brine is good for W1,a water hardening steel. Brine prevents the envelope of steam which can surround the part when it is quenched,causing uneven hardening. It is doubtful with the small parts you intend to make,that steam will be a problem. However,to make a correct brine solution,add ICE CREAM salt,stirring it into solution until a potato will float in the brine. That gives the correct 7% brine solution. I don't know why ice cream salt is best,but it is recommended in good books on tool steels.
Never quench parts in cold water. It will shock the parts too much,and can cause cracking. W1 is THE MOST TREACHEROUS tool steel there is to harden. I recommend you stay with 01 only,and make lots of parts with it until you get experienced. Then,you can branch out. W1 also moves more than any other tool steel,meaning it changes size some. This is not a lot,but if you have close fitting holes,or other close fitting needs,you might find that the part does not quite fit when you are done. 01 is safer.
The safest tool steels are the air hardening ones,like A2. They also last longer as cutting tools. However,they will decarb while heating up to harden,and will develop a soft skin that you do not want. They must at least be snugly wrapped in a stainless steel envelope. The best thing is to harden them in an inert gas filled furnace. Also,they are more critical about hardening temps. I use an electric furnace with an accurate temp. gauge. The ideal heat is within a 25º range,so again,I recommend you stay with 01 until you get experienced.
Springs are best made of 1080,which is a water hardening steel you can buy from Dixie Gun Works. I have made reliable leaf springs from 01,but the alloys in 01 make it a bit tricky for your spring to not break compared to 1080.
You STILL need to get a good book and read it several times.
P.S.: Kasenite is no longer available. A CLOSED crucible with AQUARIUM CHARCOAL will do a better,deeper case hardening anyway. Make sure the crucible is CLOSED. The lid luted on is best,but a heavy lid will do. When the steel is red hot,its pores are open,and will accept carbon. I THINK the slight gas pressure of there being a lid helps drive the CO2 gas into the steel better. There is controversy about the pressure,but in my experience,it definitely helps. Aquarium charcoal is best because it is full of tiny holes that vastly increases the surface area of the charcoal,making more gas.
