Making a rotary vane compressor
Norppu
Jun 15, 2018
296
This is the first episode of a video series of making a rotary vane compressor.
In this video I am using:
- Weiler Matador SV (1972) Lathe
- Schaublin SV-51 (1955) Milling machine
- Solberga (1975) Drill press
Join the channel:
I upload new videos every other week, usually more frequently.
If You want to see more of my videos, click LIKE & SUBSCRIBE!
You can also subscribe here
Making another part for the rotating vane compressor.
This part includes a precision hole for the bearing bushing.
I fail with shrink fitting the bearing bushing but succeed in rescuing it.
- Wohlhaupter UPA3 Boring/Facing head
- Tapmatic 50X Tapping head
Join the channel:
Nice work ! Are the pin and brass bearing are just “glued “ in ?
Yes. I decided to go the glue-way. It is Locktite ... hmmm... was it 648? The green stuff that does not let go.
Since you glued it , what kind of clearance fit do you need to do ?
For Locktite I leave something like 0.02 mm (each side).
