- Mar 21, 2013
- 4,095
I considered doing this to my PM25 while I had the head off and was gutting it for the belt drive. But then I got thinking (I was an engineer and sometimes do too much of this) that gravity causes a twisting load between the head mount and the dovetails of the column. I saw some wear marks on the head mount and column that supported my suspicions so I came to the conclusion that I want the majority of the bearing surface between these to parts to be where the highest load would be. At the bottom.not sure on the G0704 but on the G0758 i flipped the Z dove tail slide and got about 4" more Z travel.
the extreme up position gives me like 14" from spindle and table vs the 8-3/4 of the stock mill (I don't do work at the extreme but nice for tool changes) i have closer to 12" for working.
I may have overthunk it, but I left it alone. Pulling all that gearing crap out of the head reduced the weight a bit so I figured that would reduce the loading on the column/head mount and I just bought jobber length drills to help with my inadequacies in Z length.
