- Jun 22, 2023
- 728
"Kind of disheartening really, unless I am reading PM's website wrong. I cant justify buying the PM-932M because the PM-940M Gives you so much more machine for basically the same price..."@verbotenwhisky
Doing my due diligence I scoured the bright web searching for horror stories about the PM-932... I only found a few with major issues that got solved. I did find a lot of complaints found during machine setup, fit & finish, No lube or oil present, Casting sand in mating components. I did not find issues that where in such great numbers it would make the machine a high risk purchase.
It appears for the most part people find this Mill serviceable after a pre use tune-up.
Interestingly there are multiply versions of this machine with major differences that cannot be changed once purchased. 1- Gear Head, 2- Variable Speed, 3- Z Axis (Head) Positioning Motor, 4- Powered Boring "PDF = Power Down Feed" of the spindle...
Current purchase options as of 6-13-2024
PM-932V
The Variable speed model has an option -> With or without DRO.
Unlike it's bigger brother the PM-940V, PDF is not an option with the Variable Speed model PM-932V.
Z Axis (Head) Positioning Motor is also not an option on the PM-932V.
PM-932M
The manual or gearhead model comes in three flavors, + With or without DRO.
M-basic, a bare Gear Head machine.
M- Gear Head machine with Z Axis (Head) Positioning Motor.
PDF- Gear Head machine with Z Axis (Head) Positioning Motor and Power down feed on spindle.
LOL this just made making a choice even more fun.... I can have variable speed or power down feed but not both... plus what ever machine you get, you should expect issues of some type before use, So its wise to do a teardown and tune-up of the machine right out of the box.
Its ok, I'm thinking PDF any way, If I get a base model I cant add PDF later down the road...
Here is the best part of all that makes no sense,
The PM-932M PDF machine and base are purchased separately and total $4398.00
The PM-940M PDF comes with a Base and is $4399.00
I've done enough research in the last two days to make my head spin...
I am going to put this Milling Machine Purchase on hold till I get my garage all cleaned out, My lathe all set up and see how much room I have left, Then come back and figure this out...
Thank you to everyone, all the help in figuring this out is much appreciated, I've learned a ton in the last two weeks - this ain't over yet...!
it seamed like you got upset with me for pointing this out 10 pages ago lol, you are doing your homework and at the end you will have the peace of mind knowing you looked at all the important facts.
the 833 is good equipment and the g0704 is a good buy (if in decent condition) and either will help you learn. the 940/932 are also great, not really a bad decision in the group, just depends on what you are going to do with them.
