- Jul 30, 2017
- 635
5k is a lot to spend on an unknown, which is why I'm not rushing, I ask all the right & Wrong question, that being said the PM-932M PDF is a really good contender, has features I know ill kick my self for not getting... Its bigger than I want, I have the room for it, and I am sure would take much more time to out grow than say a 7X27 or smaller.I have asked on this site before for guidelines of how to match a mill to a lathe, and mostly got answers of "it depends".
Smithy apparently thinks a mill with a capacity similar to the Sieg X2D is appropriate to pair with their 13x40 lathe. Other combo mills also match roughly similar mills with their 10-13" lathes.
The OP does not seem to have any plans for the mill. Will he be happy with the 932 or 940? Maybe, probably, but with no use case that is hard to say.
Is there a chance he is buying a lot more mill than he needs?
Is there a chance that in two years he finds himself regretting not waiting and going with a knee mill?
Maybe $5000 is not a significant amount of money to others, but I'd have a hard time spending that without a very detailed need.
When I first started researching I found that the PM-833T was a complimentary Mill in scope & size to my lathe, and very expensive... I saw the PM-932M at a much better price point, after looking and looking I figured this is a good Mill to start with and add mods over time, then I look more and find out none of the PDF options can be added after you purchase the base model. to drive the final nail in the coffin - as I look I find both the PM-932 PDF and PM-940 PDF are the same price. I'm like seriously - why would I buy the Ford Ranger if the F-150's the same price.
I also agree with you on buying a smaller machine just to learn on, then chalk it up to a learning expense... You find out what you do and don't need - Can and cant do... but in this situation if you already own the worlds best lathe ( Per Me ) starting with something complimentary to it seems to make sense.
Like most everyone here on the forums I love working with my hands, and problem solving... If you give me a machine Ill find a use for it.
Thanks for the input Sir, Mike.
