- Apr 23, 2018
- 7,053
Randy, yes, the Lead-Chek works perfectly for screening. The test is sensitive around 50,000 ppm, which is the lead paint screening threshold (0.5%). It's just a color test, so no concentration, but if the swab turns red the surface is hot at the HUD/EPA level, which is good enough for this non-production work.
The powder may or may not be representative of the base metal. It has been blasted to vapor with a laser beam, which would volatilize the lead, or at least a portion, into the atmosphere. Roughing with some emery cloth and testing the surface of a coin with a Lead-Chek would work just fine, and it's probably the best solution for a home engraver to screen materials.
