It's wired back to 110v now. After I couldn't make it work two different ways on 220v I decided the heck with it and wired it back 110v.
Got the motor and switch set back up for 110 and rewired it in the breaker panel, dropped it in drive and it went backwards. Huh?
Reverse? Nothing. Okay. So I raided my trashcan for the old pieces of wire from the switch to the motor and was studying the pics from before disassembly and I had it all jacked up.
My new wire only had two colors in common with the old and I just relabled the different colors on my own. The letters and numbers in the switch panel apparently do not line up with the letters in the motor. 4 on the motor had a U beside it and 5 had V beside it. Apparently that don't mean jack. The black wire which is labeled 1 on the switch goes to 5 on the motor, not 1.
So I had U from the switch on 4, supposed to be on 1. V from the switch on 5, supposed to be 4, and 1 from the switch on 1 on the motor , supposed to be on 5.
So I had the reverse winding wired backwards to the switch, no power going to the forward side and reverse wire hooked to the starter winding.
Miracle I didn't smoke the thing. Anyway, it's back on 110v now and it will probably stay that way for the foreseeable future.
Maybe one day I'll do the 3phase vfd thing and then it'll go on 220v. I've gotva couple jobs I need it for at the moment so it's going in service as is.
I did run it a little just making sure everything else was in working order. It all did fine. Looks like I've got a half thou runout in the spindle and .003-.004 thrust forward and back at the moment.
I'll get it settled back in its spot tomorrow and level it up and it'll be good to go.
