I need to bore a moderately small hole
lesrhorer
Jul 6, 2021
358
I want to make some Epoxy molds, and part of the mold needs to have modestly small, accurate holes bored in it. In particular, the mold needs to have some 0.3060" -0.0007/+0.0007 holes bored in it. Obviously, the holes need to be reasonably smooth so the mold will easily release the Epoxy when cured. The mold seam will be radial to the hole axis, so a little mold release should easily accomplish this as long as the milling marks are not too deep. This should not be a major challenge. The holes also will not be very deep - perhaps 1/2" at most. The big challenge is coming up with a tool to handle the work. I don't think there is a reamer this size, is there? I certainly do not have any boring bars small enough to bore a hole this size, especially since my boring head uses 3/4" shank boring bars.
I have not yet decided on the material I will use for the molds - probably Aluminum, but I have not ruled out acrylic or polycarbonate. In any case, the machining itself won't be challenging for any reasonably hard tool material.
No doubt that Option 1 would be to use a reamer.
They come in any/every size under the sun, but it'll cost you $40:
EDIT: Here's a cheap used one, $7.59 with free shipping:
Option 2 would be to make up a little adapter sleeve for your boring head to accommodate smaller shanks. Then grab a appropriately sized broken end mill and grind your own. That option is essentially free.
McMaster Carr has .306 reamers in HSS and carbide... the HSS reamer is about $29...
-Bear
Oh, wow! I did not know Zoro had that service. Option 1 is definitely the way to go, especially since I don't have any broken end mills.
I would bore those holes first with a micro bar and then ream with that reamer if accuracy really is an issue .
If the hole has a seam, an interrupt of some type, you may want to consider a spiral flute reamer for the finish work. If I am understanding your description that is.
I was thinking carbide drill for a nice straight hole and ream.
What? Did you just get the mill yesterday and have not powered it yet?
-brino
<chuckle> I know! Scandalous, isn't it? In truth, I have not really had it very long, at all. That, and I am mostly working with Aluminum and plastic. Only a tiny bit of mild steel and a couple of pieces of drill rod. :)
