I was breaking up a junk 10 speed bicycle to get it out of the way. There are some parts that I am saving to repair another bike and some that I will melt (the alloy parts). As I was cutting up the frame so it would fit in the tiny garbage collection cans, a weird thought popped into my head. Could the headset be used as a light duty vertical milling spindle? A little bit of Internet searching suggested that bearing maximum speeds are mainly a function of ball material and lubricant, not size of races and not the fact that the bearing is open. The main limiting factor is temperature rise. There is a hole at the crotch of the fork through to the bore that looks large enough to press an MT2 sleeve in. My current expedient vertical head that is mounted on a horizontal mill overarm is a Harbor Freight trim rotozip type rotary tool mounted in a wood and sheet metal frame. It looks really silly, but it is rigid enough, and it does surprisingly accurate work. It would be nice to use larger end mills, though. I realize that the races are small, and the wall is pretty thin, but might this work? I didn't find anything with an Internet search, so either making a real spindle is too easy, or it just doesn't work.
