What is the biggest conventional milling cuts you're comfortable taking on horizontal milling machines holding the part in a vice?
Since I got my horizontal milling machine I was interested in seeing some big material removal with big cutters.
I'm specially interested in using 3in diameter, 1in arbor, up to 4 in long, 10 teeth spiral cutters to mill surfaces quickly. My mill has no backlash removing device so climb milling is a bad idea.
Still I tried climb milling with a narrow (1in wide) piece of mild steel and 20 thou depth of cut. It left beautiful finish,but I could see the table being pulled into the work. So milling deeper is probably a recipe for broken cutter teeth.
So I understand I should be using those cutters with conventional milling only. The problem with that is that conventional milling with horizontal cutters generates a force that tries to lift the item off the table. I've managed to successfully remove lots of material with it once, but back then I had a part I could bolt directly to the table.
This is impossible with parts one wants to mill entire top surface of. For such parts I'd like to use a vice, but I'm worried the cutter will pull the part out of the vice and break stuff.
I tried today milling a similar 1in wide piece of mild steel with 20 thou cut and conventional milling held in a vice. It held up, but 20 thou depth is not a lot. I can achieve the same with a fly cutter on a vertical mill. Is there a rule of thumb formula for a "vice pull out force"? I can calculate the lifting force generated by the cutter, but I'm not sure what is the actual lifting force a typical 6in vice can withstand and still hold the part.
