- May 3, 2020
- 342
If I was using my G0755, I would drill the corners, drill the center stepping up to 5/8, then cut out the remaining material using a 1/4" carbide endmill at 2,000 RPM. That's 130 SFM and it's as fast as the spindle goes, so there's no option.16000rpm and your getting sparks?
Why so fast?
With a faster spindle, you can have any speed but there is a minimum speed where you have enough torque to cut. I haven't personally found it and it's a Chinese spindle so the documentation is somewhat lacking. Breaking Taps (YouTube) did a bunch of test cuts in steel and found that 8,000 RPM was as low as he could go. That's 525 SFM with a 1/4" endmill.
