Group Project: Dividing Head - The Build
Man I wish I knew how to use it and had the machine running. My machine actually has a Hobbing function where it can sync the mill spindle and the turning spindle to do this.
  • Like
Reactions: rwm
Still playing on how to best cut the gear. My 6 point cutter did not have side relief and struggled to cut deep enough. The rigidity of my toy Sherline was also an issue. Even Viagra did not help this.
I decided to try single point cutting. I went through my scrap bin and found a 6mm chunk of carbide. I break a lot of drills. I ground a 14.5 deg taper using the toolpost grinder (diamond wheel ) on my lathe and then cut a flat surface to the center point:
I mounted this in a 5/8" mandrel. I tilted the rotary table 4.55 deg nose down (proper lead angle) using trigonometry and an appropriate height block:
I machined two gears this way and they came out good. I then ran them in against my shop made hob. I think they will work well.
I have to say, the carbide cutter held up perfectly; I was afraid it would break. The alloy steel hob is getting significant wear from the bronze is is now probably shot. I'm surprised the steel did not hold up better. BTW this method is super tedious because you have to cut 40 teeth to specific depth at 9 deg increments. It takes a long time and is easy to **** up.
@rwm
I've been lurking since the beginning of this adventure.
I'm relieved to see that you finally went to the 'one tooth at a time' approach.
Now that you've got a (some) single pointed gear, I'm wondering if using the Acme tap, at full tooth engagement depth (gear free wheeling) as a 'chaser' would serve to be certain of a proper (non- interfering) gear tooth profile. You could set it up and turn the spindle (tap) by hand to try it out. Just a thought. YMMV.
I tried that. It works but may not provide an advantage now that the teeth are full depth. Believe it or not, the tap and the acme threaded rod I sourced from MMC do not have exactly the same tooth shape. As noted earlier, you should run in the gear with the same screw you intend to use. Also, single point cutting cannot give the exact correct profile of the teeth compared with running against a screw or hob.
I got through all but one of the main bases this weekend, and while I had the rotary table set up. . . . this:
Some look better than others, but they are all functional (else I wouldn't have been able to machine them.
I make an "arbor" of sorts to hold the bases to the rotary table so that I could machine the round on the outside of the hole. I clamped these clamps to the same arbor, and then is just a matter of going round and round.
  • Like
Reactions: rwm
Those look really nice. Are the blued or is that just the lighting? I assume this is a design revision from the original drawings?
Not blued. I heat in a toaster oven to 450, then dump them in used motor oil. VERY rust resistant.
The divergence from the plan was to make the clamp one thickness over as much of the diameter as possible in order to eliminate all the bending happening in one place.
  • Like
Reactions: rwm
