If we are sure that this is a go, can somebody let me know (1) how much of (2) what material is needed for the spindle shafts? Medium carbon steel (such as 1045), 4140 prehard?
I have all of my weekends to work on this. All my other fun time activities will be pushed back.
Unfortunately, we won't know exact dimensions until we finish with drawings, but the spindle should be 5" or so, I would think. 3" to pass through the trunnion, 1/2" on the rear for the nut, and 1.5" for the nose?
I will try to tackle it. I will of course back out if i have trouble with anything once i get a print so i dont hold you guys up.
1) Drawing (
@Flyinfool)
2) Worm, Gear, Selector Crank Arm, Spindle Lock with Indexing Pin (
@Shotgun ) - - 7071 aluminum
3) Spindle Shaft (
@erikmannie) - - 4140?
4) Trunnion and Bearing (
@ttabbal)
5) End Plates
5) Base (
@ErichKeane) - - A35?
6) Worm Crank and Selector Pin (@Bento) - -
7) Index Plates (
@Ianagos)
8) Chuck/Front Index/Backing Plate,
Currently, each participant will be responsible for 7 copies of the part they've agreed to make. But, we still have a couple sections that no one has signed up for. (I just signed on to making the spindle lock.) None of this will be final until we've finished with the drawings, of course.
At this point I have two questions:
First, what are y'all's expectations of timeline? (weeks? months? sometime before Jesus comes back?)
B) What do you envision making the part you signed up for out of? I'd like
@Flyinfool to have that guidance as early as possible.
