We're up to 6 participants so far. The goal is for everyone to end with their own dividing head.
@ErichKeane If you can't find material that will work as the base, we can swap out. I have material to make two bases sitting on the shelf, and I can get another 15ft if I want it. Worst case is, I could ship you the acme rod, hob and fixture I made for making gears. I'm good either way.
What the "keys" you are referring to?
This is why I mentioned that I will need to confer with each person about the part(s) they are making so I can taylor the design and drawings to work with their material and machines as well as fit up with everyone else's parts. There are many features that can be easily changed but may also affect other parts that can be easily changed to match.
The keys are removable tabs on the bottom of the unit to bump against the slots in the table for alignment.
Yep, those are the keys I mean! I envision cutting a square '+' into the bottom. You can then put a key into one of the directions to center it on you T-slots, similar to the older Kurt Vises.
I definitely think a few review cycles of customizing to the group manufacturing capabilities and and material availability (plus the group's needs) is a good idea.
