Currently, yes one end plate is part of the base. Made from a single piece of heavy angle iron. The material I have is 6x6 angle that is3/4" thick. The Auxiliary Base (and, yes, I did make up some of my own names, 'cause I didn't know that the proper ones should be), the Auxiliary Base could be bolted to the outside of the Main Base when the Trunnion holes are cut. Also, I did draw slots for clamping, but I really don't know what the range of T-slot sizes could be, so they were very much a SWAG.
@Brento Would your watchmaker's lathe (I'm sorry that I don't know what that is) handle making the Worm Crank? If you look at
post #74 of Mark_f's thread, the worm crank and indexing pin look like small detailed parts. Much of it could also be made from aluminum stock. Now I'm going to go research what a watchmaker's lathe looks like.
1) Drawing (
@Flyinfool)
2) Worm, Gear (
@Shotgun )
3) Spindle Shaft (
@erikmannie)
4) Trunnion and Bearing (
@ttabbal)
5) End Plates
5) Base (
@ErichKeane)
6) Worm Crank with Sector Arms
7) Index Plates (
@Ianagos)
8) Chuck/Front Index/Backing Plate, Spindle Lock with Indexing Pin
