I need some time to catch up on Mark_f’s thread.
I would have chosen the spindle, but it looks like Ernest (presumably Shotgun) has already claimed this group of parts. I don’t think I could have made a gear. If needed, I am willing to knock out just a spindle; I see nothing on the spindle that worries me. Hobbing gears, not so much.
If not the spindle, hopefully something on the lathe. I have a large precision lathe, but my mill is a PM-25MV.
I am up for anything. What group of parts is still up for grabs?
I will get caught up on the Mark_f thread in the next 24 hours or so.
I can let you have the spindle, @erikmannie. The stock I have to make spindles out of is marginal anyway.
Dealer's choice, but the worm gear crank, along with it's bearing, is another part that is going to need some tight tolerance lathe work. I've bought a 12" length of 1" acme rod a while back that I was using for the worm. So far, I've used 1" of it to make a hob for gear making, and 1" for the worm of the gear set that I have made. I could cut the rest to 1" sections, then drill and tap them. Mark_f used a nut to secure the worm section, but I don't see why we couldn't just screw it onto the worm shaft directly.
So far what we have for assignments is:
1) Drawing (@Shotgun /someone is considering but not yet committed)
2) Worm, Gear (@Shotgun )
3) Spindle Shaft (@Shotgun /@erikmannie)
4) Trunnion and Bearing with End Plates
5) Base
6) Worm Crank with Sector Arms
7) Index Plates (@Ianagos)
8) Chuck/Front Index/Backing Plate, Spindle Lock with Indexing Pin
