- Jun 29, 2014
- 4,300
Make sure you rotate your shaft in the bath periodically, or have anodes positioned around it. Plating is line of sight from the anode perspective.I was thinking a Watts-type bath using Nickel Sulfate and Boric Acid could be something to try, perhaps with a few more ingredients. There are lots of nickel salts plating solutions, and various plating properties one can end up with. I can manage about 50A at 5V, but in our case, we can substitute time for current. The ions will plate anyway. That calculation showed me that 58.69 grams of nickel needs 2 x the number of electrons it takes to liberate 1mol worth. I figured that in 2 hours, the 7200 second worth at 0.5A would deposit 1.095grams. Getting to efficiency, and without cooking it up to 50C, we can get about 50% of that. Half a gram is not much, but is enough to fill some grooves.
You may consider reaming the bearing sleeve for this shaft rather than corrupting the nickel surface. Depending on your plating thickness and adhesion quality, you will likely flake or chip the nickel when trying to turn down the surface. Your depth of cut is going to be likely deeper than the thickness of the plating.A thick plating surface will pretty much follow the profile of the surface it started on. You could have a plating thickness many times the size of the imperfection, and still see the imperfection replicated on the top. I think a "filling repair" would be to plate on enough to fill the groove, then cut back to the original dimension. In my case, the oil film should be thicker than the grooves depths, so this time, the value in the plating is about corrosion protection.
Yes indeed on the castings. I love that!
I wonder if one can get the plating to work through wet cotton wool swab, with solution, like you can do with gold plating? That way one could "go over" the machine surfaces exposed to rust, instead of having to dunk the whole thing in plating solution.
I would think it is possible. I would really like to figure out how to do that. I suppose painting over the nickel plating is an option as well but that is a better option for those of us with big tanks and not hobbyists.
