- Mar 20, 2014
- 416
Curious how you power the ELS. Is there a separate power switch, or is it on whenever the lathe is powered up? I'm thinking of having both, basically a switch downstream of the lathe breaker dedicated to the ELS.
The SC4 has a IEC socket on the back of the headstock. It’s there to provide mains power whenever the lathe is turned on for an optional milling head. As I don’t have that, I’m using it to power both the DRO and the ELS. I can switch either of those off As the ELS has a switched power I out socket, and the DRO has a power switch on the back of the display.
