- Feb 1, 2015
- 10,089
The correct ratio could be set by changing the lead screw pitch. Since I am driving at 1:1 (same lathe) and James is driving at 3:1, my lead screw will turn at 3x his. If I set the lead screw pitch at 36 tpi, , it will advance 1/3rd as far for each revolution and all should be good. However, this seems a kludgy way to do it.Watch Part 2 for how he works out the numbers. I'm facing the same issue, made more fun by the additional reduction inside my QCGB.
I know that James ran 1:1 when he ran the stepper and he talked about possibly running other ratios to optimize so I suspect he has a variable for that ratio.
