- Jan 25, 2015
- 2,554
KInda points me back to the start capacitor being duff.....but I'm no electrician or electrical engineer. FWIW.
Ran across this on a google search, so take it for what it's worth:
"Why is the single phase motor changing the running direction without changing the wire?
There are a few possibilities.
"George Stratton, President at G. E. Jones Electric Co., Inc. (1971–present)
I must assume you have a split capacitor type single phase motor because of the problem the you are alluding to. I would suspect a capacitor problem. Or perhaps a short circuit between the condenser winding the oil capacitor is in series with and the main winding in which case the motor should be drawing excessive current.
Now for the other types of single phase motors…
A split phase, both with and without an electrolytic start capacitor(s), requires a switch to energize the start winding. A bad switch or open capacitor would cause the motor to simply buzz…not rotate. However if you physically turn the shaft in ether direction it will run. Some larger split phase motors have oil capacitors placed across the starting switch contacts. I suppose it may be possible that there would be enough capacitance there to boost the start winding one way or the other without a load. Doubtful though.
The other type of single phase motor is the shaded pole motor. That motor can run in one direction only but can be reversed by removing the rotor and placing it back in the bore in the opposite direction. Therefore…No way this type motor would cause your problem."
Don't know if any of that helps, but more knowledge is always better than less knowledge.....
- Your motor may be lightly loaded (e.g. requiring very little starting torque to start the load) and the start centrifugal switch, the start capacitor or start winding may have failed. In that case the motor will sometimes randomly start in either direction (though more likely simply stand still and hum)."
