Don't be this guy! (Me)
cdcava
H-M Lifetime Diamond Member
Apr 11, 2020
25
So I'm fairly new into the hobby, and traits that serve me well while doing it are things like curiosity, stubbornness, cursing, being creative (aka "Try everything despite the simple answer staring at my face) and my OCD-ness. The last one I apparently faltered (In various ways) on at the very last second of my hobby day because I ended up in several medical offices to fix it.
What needed fixing? I got a very (VERY, nothing macho about this size) small piece of rusty metal embedded in my eye. It was so small, I didn't even know it happened until a couple hours later when exactly half of one eye was bloodshot red. My wife (A doctor) took a look and assumed it was just on top of my eye, and tried flushing it out with a lot of water (Which was way more painful than the rusty fleck). She then took a closer look at it and realized that it was indeed IN my eye, and not on top of it (As if slightly stuck). She immediately assumed it was a small rusty fleck, and offered to remove it (This part sucked a lot). She took a sterile swab and "pushed" (I call it stabbing) at the area to coax out the fleck. Unbelievably she did get a chunk out but unfortunately I still had the "spot" in my eye. After looking up some info, she theorized it was a "Rust Ring", basically the rust of the embedded metal literally oxidized the cells surrounding it. The medical advice for it's resolution is pretty split on the matter.. some say to leave it and it'll go away in time, and others recommend removing the Rust Ring out of the eye.
Anyway, I had to visit one office to get my Tetanus shot (It had been almost ten years exactly since my last one, and the another office to have an eye doc remove the Rust Ring (He got it in one go.. it looked just like the fleck my wife got out). All this during the Pandemic so I was geared up in mask, Clorox wipes, and more sanitizing fun stuff.
So how did I get this fleck in my eye? Was I a moron that didn't wear my safety goggles, grinding mask, or what have you during metal grinding, chopping, or sanding? Nope. The only time I took off my safety gear was when I was putting everything back and then started walking back into the house... but remembered last second to "blow out" my garage with my blower. I was too lazy to slip on some goggles and figured I've NEVER had an issue doing this before (Not wearing goggles at those times too). I goofed and pointed the blower at an enclosed corner causing blow-back, and in went the piece. Always wear your safety equipment! While we're on the subject don't forget about updating your Tetanus shot. Fun learning experience. :cautious:
Yep have been to the eye doctor three times for metal in the eye. One time I was even wearing my safety glasses it came in from the bottom area of the glasses. The worst is when the eye doctor says don't move and keep your eye open while she has a little pencil dremel carving out the piece of metal in your eye. Your eye will rust with metal in there for a long time
You only have two and don't wanna have just one wear your protection whenever needed!
I got a piece of rusty metal in my right eye drilling rivets out of a ball joint. I went in to the ER where an intern tried to remove it with a hypodermic needle. He got part of it out and said the remainder was a rust ring. Over the next few days, the pain got worse and out of desperation, I held a large magnet as close as I dared to the eye and popped the remainder of the sliver out.
On a later visit to an ophthalmologist to remove another object, I was told never to use a magnet to remove a piece of embedded steel in the eye as it could do more damage.
As a result of the scarring from that first incident, I now have double vision in that eye.
Was doing a lot of grinding and welding using safety glasses when finished at the days end showered and got soap in my eye
Must have rubbed it about midnite eye was sore
Next morning after no sleep wife drove me to clinic had grind particles lodged in the eye
They said after removing to see my doctor for follow up
Eye still hurt like hell went into clinic at the food chain store while my wife picked up groceries the doctor took the crap out
in about 10 minutes eye felt a lot better no problems
sometimes 2nd opinion is the solution
Just FYI also, with us working with metal, have an Xray done prior to any MRI procedure, they are supposed to ask first, but if they don't....
So I'm fairly new into the hobby, .... Fun learning experience. :cautious:
Man, these eye stories are freaking me out!
cdcava, thanks for sharing that. IMO you have the right attitude, recognizing the misjudgment and learning what you can from it.
It's all about risk management.
Had the same embedded metal issue including the rust ring. My ring didn't go away. so it had to be "ground" off my eyeball, with what looked like the pencil grinder I have. Wasn't very pleasant!
I have been fortunate in getting good eye doctors. Had them ground out that will scare the crap out of you. One doctor just used a cotton ball which he shoved in my eye, the cotton fibers snag the chip and it comes right out. one time my eye was hurting and went toe doc, the chip was gone but the rust ring was driving me nuts. The doc had me put some drops in my eye for a couple of days and when i went back he took a probe and just lifted the ring off the eye an laid in on a gauze pad. In porting 2 stroke barrels we would wear safety glasses, wrap scarves around our head and then wear a face shield. The chips would still get through but lost a lot of velocity
