- Aug 20, 2024
- 21
AKA the 1224G I believe. 80's vintage, 12 x 24 belt drive, made in Taiwan. Although I've had this machine for awhile, I never did a lot with it, but my circumstances have changed and now I'm focusing on my machining again. Recently did a 3 phase conversion, I made a silly mistake early on, but that's now sorted. But I'm still struggling with feeds, speeds, and DOC with this thing.
So for those of you running this machine or the nearly identical 36" version, what's your max DOC, and at what speed and feed? Cutter info would also be helpful, I mostly use HSS, but I also have some carbide, although nothing exotic. I'm mostly concerned with steel at this point, my previous use was almost exclusively aluminum and plastic, but I'm planning to do more with steel going forward.
And before anyone tries to ding me for not doing my own research, yes, I know about SFM, the rule of thumb formulas, and I've got lots of charts. I even know that they're all more or less based on the data from the Machinist's Handbook. What I'm after here is real world use with machines the same as mine, or at least close. I don't feel like I'm getting the performance from this machine that I should be, but all I have to compare it to is YT vids, so I'm looking for a reality check to determine if my expectations are reasonable or not. Thanks!
Dave
Dave
