alright, stethoscope helped rule out the nose / ACB. so it was either the DGB on top or the pulley assembly. I let it run at 2k rpm for 10 minutes and checked temps. The nose was fine (100F), the top of the quill was cold, but the pulley was hot (140F).
How could that be the case? I didn't touch anything on the pulley assembly. I unfortunately have no way of knowing if it was bad before I pulled everything apart....but it certainly wasn't making any knocking noises like it is now.
I've also just finished running the pulley assembly only (spindle not installed) to see how it does. Knocking is mostly gone but it still gets pretty warm (100-120F). *MAYBE* my belt tension? It actually feels a little loose if anything (this machine isn't easy to tension well).
EDIT: to include that the spline fit from pulley to spindle is not great. lots of slop in pitch/roll. and it sure sounds like I can recreate the knocking by rattling that fit.
