well that was a hoot. only realized after getting the new ACB that the old one was put in upside down. Seems as good an explanation as any.
One other adventure: I was thinking that I already had the thrust bearing so I'd just install it, then turn a new spacer to see how it runs. That bearing was from mcmaster and had two different sized washers! 30mm and 32mm. Can't catch a break so I went with the stock (not to drawing) assembly.
TIR is between .0004 and .0007. Far better than I can do. Google tells me to check the temp of the spindle after awhile to make sure preload is fine. Are there any other methods?
Finally worth noting that Grizzly has been slow to respond here. It took them awhile to agree that my spindle was different than their drawing and now we're waiting for them to "contact the factory". Will share any news if I get it.
